Transom replacement
Old 02-01-2016 | 03:16 PM
Default Transom replacement
I have a 1998 353 Fastech. The transom is rotted in it. The formula boats has a lay support it looks like that goes up the back part way . Can that be cut out or does it have to stay? Has any one replace the transom in a Fastech and do you have any suggestions?
1stFormula is offline
Old 02-01-2016 | 07:00 PM
I have done a few transoms on my Formulas. Mine are older. I had to cut everything about 8 inches from the transom. Thats the only way to make enough room to get the new plywood in. I bet you will have to cut it, then replace it later on.
79formula is offline
Old 02-01-2016 | 07:09 PM
Is your bilge the one with the whole fiberglass innerliner deal?? If so talk to glassdave, he has one of those apart right now...
phragle is offline
Old 02-01-2016 | 09:55 PM
A new transom comes under the category of " nothing money won't fix". I have done it twice.
BenPerfected is offline
Old 02-03-2016 | 12:52 AM
glassdave's Avatar
Neno the mind boggler
Your boat has a full bilge liner with integrated stringers, the only wood in the stringers is a stack right at the mount for compression. Its a bit of a chore to get around but not impossible. Its actually more of a surgical procedure. You can cut parts of the liner but re installing those must be done with care, you will also need to be creative about how its done to insure 110% of its integrity.
08 OPA High Points Champion
glassdave is offline
Old 02-05-2016 | 01:48 PM
Thanks for all the input. Does not look like it is going to be an easy one.
Old 02-20-2016 | 08:35 AM
1st Formula Any idea why it went bad and what made you realize it was. I have a 98 as well and want to check it out. Have done a ton of work so far and the transom is one thing I worry about although it seems solid.
DoubleThunder is offline
Old 02-21-2016 | 09:43 AM
Where is the rot and how do you know it is rotten? I would do a thorough drill test to see the extent of the rot. I watched a former member named borgie cut his whole transom up and it looked pretty damn solid to me.
JRider is offline
Old 10-19-2016 | 01:59 PM
So sorry for just now getting back. We think It started where the exhaust went threw the starboard side. I have taken the thunder box off of it. I am convinced that was the issue.
Old 10-19-2016 | 02:00 PM
It was very bad. It had to be completely rebuilt. They said it was one of the worst they have seen.
