Moisture meter for inspections >
Old 02-04-2016 | 02:15 PM
From: East Texas Waterfront- running errands if anyone asks
Default Moisture meter for inspections
How effective are these pinless moisture meters for detecting wet transoms and stringers.
This should work through Fiberglas. Right? Shows depth of 1.6".
http://www.extech.com/instruments/pr...=11&prodid=631
[ATTACH=CONFIG]550534[/ATTACH]
Flightplan is offline
Old 02-04-2016 | 02:22 PM
Ohm meters can work well also, take out a few screws inside engine compartment and stick the probes right in. if its wet it will tell you,
class6 is offline
Old 02-04-2016 | 03:19 PM
northernoffshore's Avatar
thermal style ones work good... i have a skipper plus
northernoffshore is offline
Old 02-05-2016 | 12:42 AM
I highly doubt the one pictured will work through fiberglass, at least not accurately.
Its for building/construction materials http://www.extech.com/instruments/re.../MO257data.pdf
Griff is offline
