used bravo 1 1.5 ratio gears >
Old 02-11-2016 | 08:44 AM
Default used bravo 1 1.5 ratio gears
I have a used low hours upper gear set. 1.5 ratio(32/27). One of the brass rings has some chipping on a surface, other than that they are in great shape. At one time during my bravo blues I was buying spare gears and just repairing uppers with gears. I had MUCH better luck with these gears vs the xr gears. 550.00 plus shipping. Call or txt 317-538-3100. [ATTACH=CONFIG]550877[/ATTACH][ATTACH=CONFIG]550878[/ATTACH][ATTACH=CONFIG]550879[/ATTACH][ATTACH=CONFIG]550880[/ATTACH][ATTACH=CONFIG]550881[/ATTACH]
Attached Thumbnails used bravo 1 1.5 ratio gears-image1.jpg   used bravo 1 1.5 ratio gears-image2.jpg   used bravo 1 1.5 ratio gears-image3.jpg
used bravo 1 1.5 ratio gears-image4.jpg   used bravo 1 1.5 ratio gears-image5.jpg
indysupra is offline
Old 02-11-2016 | 09:45 AM
Sick Stinger's Avatar
Brotherhood #1
I believe I have a couple brass rings here if needed
Sick Stinger is offline
Old 02-11-2016 | 12:04 PM
As a fairly competent shade tree mechanic how difficult are these to drop in? The previous owner switched out the 1.5 for 1.65 and I wouldn't mind switching them back as I increase power rather than re-prop. Drop in, are is there some grey magic to it?
Baja Rooster is offline
Old 02-11-2016 | 12:07 PM
They are super easy to change. Just need to check gear contact after assembly. You can buy the few tools you need off eBay for a few hundo. I think the guy who makes them posts on here.
Old 02-17-2016 | 10:15 AM
Old 02-19-2016 | 09:08 AM
I was told that I can use the bravo 1 upper gears for my Blackhawk drive is this true to be if so might be interested.
craigdskilling is offline
Old 02-19-2016 | 01:34 PM
Yes they are the same gear.
Old 02-19-2016 | 03:25 PM
Are these the same as the b1x gears? And are the stock gears always 1.5 ?
1989mach1 is offline
Old 02-19-2016 | 04:20 PM
They are not the x gears
Old 02-20-2016 | 07:09 AM
how much for the brass ring.
