Cig on board charger >
Old 02-12-2016 | 09:23 AM
F-2 Speedy's Avatar
Default Cig on board charger
I have a factory battery charger in my TG, works fine, will it go into monitor / maintain mode if left plugged in ?
F-2 Speedy is offline
Old 02-12-2016 | 10:42 AM
ROB FREEMAN's Avatar
good now I'll use mine. Lol. Sounds like they charge then go to maintain after charged. I'll problem only turn mine on three times a winter for a day. Though,, oh chit I misread you're post. I hope it works that way. Let me know. U be gunny pig. 😊
ROB FREEMAN is offline
Old 02-13-2016 | 07:18 AM
F-2 Speedy's Avatar
Well Rob, 75 views and nothing
Old 02-13-2016 | 07:25 AM
In the summer I have it plugged in with the charger on all week and never had an issue. It's not the original. Not sure if they have different set ups
sonic700 is offline
Old 02-13-2016 | 07:27 AM
I leave mine plugged in all the time never an issue .fact install on 2003 cig
smokin' gun is offline
Old 02-13-2016 | 07:46 AM
seafordguy's Avatar
Leave mine on for longer periods a lot.
During the winter I usually plug it in a half a dozen times for a couple days each time
seafordguy is offline
Old 02-13-2016 | 07:48 AM
jbraun2828's Avatar
Mine stays plugged in all winter. Has a red light on when it's charging and a green light when it's maintaining
jbraun2828 is offline
Old 02-13-2016 | 07:51 AM
My 2007 uses a Factory installed Dual Pro. http://www.dualpro.com/project/professional-series/
You may want to look a what series or model charger you have to see it specs , most chargers over that last decade or so are designed to be left plugged in (so they say).
I checked it often the first day I left the boat plugged for the same fear of leaving charging batteries unattended.
As advertised to dropped to 3 millamps and voltage remained at 12.9 on my test meter with no battery temp at all.. Good to go.
Keep in mind that the health of the battery will determine if charging or just maintaining the battery is needed. A battery with issues can keep the maint free charger cycling and working continuously.
I still check them every few days or at least weekly . As Jbraun stated green lights are comforting!
cmattj is offline
Old 02-13-2016 | 08:55 AM
F-2 Speedy's Avatar
Thanks guys, the boats four hours from me, I'll check the model # next time I'm there, I currently have two separate chargers on the batteries that do have maint. mode
