598ci 1300hp with 5.0 whipple >
Old 02-19-2016 | 01:49 PM
Default 598ci 1300hp with 5.0 whipple
Big POWER marine engine top of the line build NO expenses spared, build cost was 75K!! Runs incredibly well, no issues with this motor!!
Peak Torque is at 1150 at 4800-5000 RPM
1326HP ON THE DYNO WITH ALL ACCESSORIES, WET HEADERS
$30,000.00 obo
1326HP with race fuel
1190 with pump gas
Mefi computer
Merlin III 10.200 Block with Billet main caps
Lunati Pro Series blower crank 4.5” stroke
Lunati Parabolic beam billet rods
JE custom forged blower pistons
Total Seal TS1 Gapless rings
Cleveite HN series bearings
Hays billet steel flywheel-52 lb
ATI Super Damper balancer
Custom 14 Qt. offshore oil pan and pickup
Melling High volume oil pump-blueprinted
ARP oil pump drive rod
ARP oil pump stud
Billet aluminum timing pointer
Custom ground hydraulic roller camshaft
Morel High RPM roller lifters
Manley pushrods
AFR CNC cylinder heads Ported 357/385
Manley Severe duty intake valves
Manley Extreme Duty Inconel exhaust valves
ISKY valve springs
Competition Cam springs cups, 10* retainers and locks
HP valve stem seals
Jesel Sportsman Series rocker arms
ARP head studs
Rear main seal
Oil pan gasket
Timing cover gasket
Cometic head gaskets
Bell housing dowel pins
Brass freeze plugs
Cam plug
Fuel pump block off plate
Whipple 5.0 serpentine belt system
Whipple 5.0 efi supercharger
remote 13 plate oil cooler
whipple mo tec intercooler
Hurricane Big tube headers
Hurricane custom tails
Hardin marine mufflers
Imco hp transom plate with hydraulic steering
Imco scx drive Upper
Imco scx drive Lower
2101l90 Sea strainer
2101sr Sea strainer
• 1300hp @ 6200 RPM
• Torque 1000FT/LBS @ 2500 RPM
• Always run AV 100 octane fuel
Nikkie342 is offline
Old 02-19-2016 | 03:22 PM
So is the drive and transom assy is included with the motor?
598 Formula is offline
Old 02-19-2016 | 04:11 PM
Pics?
mach 1 2450 is offline
Old 02-19-2016 | 04:37 PM
[IMG][/IMG]
[/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 02-19-2016 | 04:39 PM
Not included in price but also for sale
Old 02-19-2016 | 04:48 PM
LOL, what boat is that in?!?!? thats a fast single
launchpad475 is offline
Old 02-19-2016 | 04:57 PM
It's in a Magic Scepter 28
Old 02-19-2016 | 07:53 PM
Pics and price of drive separately?
Old 02-20-2016 | 07:40 AM
Can you better separate which items are included at the 30k asking price ?
Shibby1485 is offline
Old 02-20-2016 | 10:18 AM
Price for full drive assembly is 17,500
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
