HaxbySpeed
Old 02-19-2016 | 04:05 PM
Tinkerer's Avatar
Default HaxbySpeed
can you call me or give me a number so I can call you.
I put together a list of pieces to install EFI on my 598 and I would like your opinion please.
Steve 616 723-1720
Tinkerer is offline
Old 02-19-2016 | 10:16 PM
steve,did he contact you?
mike tkach is offline
Old 02-19-2016 | 10:40 PM
Tinkerer's Avatar
Yes he did.
I have a list of parts I need him to look at.
AEI-12301 10 micron post filter
AEI-12304 100 micron pre filter
EDL-3658 fuel rail
EDL-7136 intake manifold
FST-54091 throttle body
HLY-12-890 fuel pump
HLY-512-504-5 fuel reg.
HLY-522-668 fuel inj.
HLY-534-10 coolant temp sensor
HLY-534-20 air temp sensor
HLY-538-13 MAP sensor or should I get the 3 BAR?
HLY-554-100 O2 sensor
HLY-554-102 pressure sensors ( 2 )
HLY-554-113 ECU
HLY-556-101 DIS kit
HLY-556-111 other parts of DIS kit
HLY-558-104 main wire harness
HLY-558-200 injector harness
HLY-558-308 power harness
MOR-65090 10.2 spacers for intake
MSD-8513 distributor hole plug / oil pump drive
What do you think???
Anything I am missing???
Tinkerer is offline
Old 02-19-2016 | 10:57 PM
BUP
Yes AED 850 HO modified carb.
just messing with you.
Throttle cable hardware ?
BUP is offline
Old 02-20-2016 | 08:31 AM
Tinkerer's Avatar
What would you suggest. Never built an EFI motor. Unless you want to count the HOLLEY first generation EFI throttle body system that I installed on the Glastron.
Tinkerer is offline
Old 02-20-2016 | 09:51 AM
Fuel lines and a provision for a return line to the tank. More of a fabrication/installation issue than parts but none the less...
horsepower1 is offline
Old 02-20-2016 | 10:04 AM
Tinkerer's Avatar
Yeah I figured there would be a LOT of hardware and plumbing. My tanks have provision for return lines. I will put together a list of parts once I start the install. I am just trying to get the big ( and expensive parts) in one order.
Tinkerer is offline
Old 02-20-2016 | 03:07 PM
For a return line, you can use a billet aluminum radiator hose insert used for an added temp sensor for aftermarket gauges. Just drill and tap the original npt hole for whatever size you need. Let me know if you need an example.
ACrooks69 is offline
Old 02-20-2016 | 04:07 PM
Tinkerer's Avatar
Both of my tanks have a tap that I can use for a return line.
Tinkerer is offline
Old 02-20-2016 | 04:10 PM
Well that makes it easy
