Need help nordic 28 t444e parasail boat >
Old 02-21-2016 | 07:16 AM
Default Need help nordic 28 t444e parasail boat
Hi guys im in Cambodia with a 1995 nordic 28 parasail winch boat 7.3 diesel t444
Got the boat from the US and since its here we ran into a couple of problemes ! Its got very low hours but dint run for many years ! First issue i have at the moment is the bravo 3 when hot sometimes wont go into forward , it can take 5 to 10 seconds before engaging and if i give it a little rev it goes into gear right away ?!
Second probleme is the turbo , we put a new one in , the original one the bearing was ****ed . It runs great but the lag is huge !! Any solution to that probleme ? For island tours its fine but with the parasail its very anoying
Any way i can crank a few hp on that t444 or we should leave it as is
Thanks for your help Parasail Cambodia
Ericrunner is offline
Old 02-21-2016 | 08:28 AM
Wobble's Avatar
SORE MEMBER
The bravo might be down to shift cable adjustment or damaged shift cable. That motor has not been available here for years, I understand that they were used more recently in Australia. Found this vid on common problems related to the motor https://www.youtube.com/watch?v=KWiP1DcwsP0 hard to find much on the marine version. Good luck
Wobble is offline
Old 02-21-2016 | 10:22 AM
Hello , How is the Parasailing on that side of the world? As far as the drive goes , sounds like the cone clutch is worn , but you could start with a drive oil change ( use the Merc gear oil , is it available? ). It may buy you a little time. Make sure linkage is free in drive.
As far as 7.3 diesel , that lag is just where you dont need it , annoying as hell. Most of those were replaced with 454 gas ( perfect power and not expensive to repair / replace , but a gas engine.) or 315 Yanmar ( bolts up to Merc , but expensive and hard to find ).
With the chutes we fly now ( 40' + dia.) most guys that still fly Nordics are using 496's and 502's. Good Luck and Be Safe!!!
PARASAIL941 is offline
Old 02-21-2016 | 06:39 PM
Parasailing is great here we fly arround the islands at Koh Rong and Koh Rong Samloem . We use a 33.5 with dampers for heavy winds and a 37" for regular days . Im not planning on changing this t444 as the diesel here is 47 cents a liter and petrol is 1$ plus the motor as only 650 hours ! The shift cable seems ok i did pull the leg appart from the transom a few time already to replace shaft , seals ect... My guess is the cone clutch is glaced so i will try to ruff it up seems like a quick fix if it will get me threw the end of the season before replacing it ! I did put some new oil in 30 hours ago , merc oil .
As for the turbo im planning on installing a air tank so i can spool the turbo up and get rid of the lag .
Getting parts here is a big probleme , need to order from US , Australia or if im lucky Thailand
Old 02-21-2016 | 10:53 PM
Thats the international slash ford powerstroke 7.3. Not a bad v8 diesel, and i dont really care for fords. obtain or make the injector tools, dont run crappy oil , and they will actually last a foolishly long time .
put some money aside for injectors when the time comes. run non silicate coolant in closed cooling system for best results . (Blue premix)
airjunky is offline
Old 02-21-2016 | 10:56 PM
Put a permenant boost gauge on it too.
airjunky is offline
Old 02-22-2016 | 02:11 AM
We run fully synthetic oil castrol 10w40
What do you meen by injector tool ? I pulled them off just using a 1" wrench ! They wont last long ?
As for the coolant i will check what we put in cant remember thanks
Old 02-22-2016 | 06:52 AM
lag is NOT huge on a well maintained well running T444E international check double check fuel tanks , fuel quality , new filters , check lines fittings test for leaks , / oil new filters new synthetic or semi synthetic oil / mix couple qts trans fluid with new oil as flush run / new filters new oil , new air filter , oversize cold air filter will help / those motors are legendary u should have neck snappin tq acceleration , if a chev 454 keeps up u got HUGE issues
hotrodford is offline
Old 02-22-2016 | 06:55 AM
everybody yaps about extended oil changes , remember its oil that runs this motor like injectors / maintain oil filter changes and drive it / check for any boost , drive exhaust leaks
Old 02-22-2016 | 07:04 AM
You can get Alliant injectors for it, they are pretty good injectors, I have used them for 7.3, 6.0, and dt466 you have to buy them through a dealer http://alliantpower.com they are usually around 250 each with core return
Brandonb_05 is offline
