When do "you" stop pumping grease in hub? >
Old 02-22-2016 | 08:03 PM
Default When do "you" stop pumping grease in hub?
As the title states, When do you stop?
After it pushes through the outer bearing or till if fills up the dust cap.
(I have spindle lube torsion axles)
Why I ask... I am in the process changing all bearings and ended up changing all wheel cylinders b/c the bleed screw was rusted off.
As I pumped them back with grease, I let it collect till you can't see the bearing, but usually pump it till it almost comes out the dust cap, then put the lil rubber insert back in.
Oh... I bought this lil pneumatic brake fluid pump from HF and it works pretty good!! It comes with a fill bottle you put in the master cylinder to keep it full and you put the pump on the bleed screw and pull the trigger! It sucks the fluid through the line and then you just close the bleed.. Voila... You sucked all the air out!
nailit is offline
Old 02-23-2016 | 01:05 AM
I have the same type of axles. I fill till the dust cap is about 1/2 full and never had an issue.
Basically fills around the outer area of the dust cap, but not the center area where the zerk is.
Griff is offline
Old 02-23-2016 | 09:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
On a fresh bearing install, I pump until I see grease coming out 360 degrees around the outer bearing.
Then I take the first trip, of at least 25 miles or so, and check again.
Remember, pumping too much grease in there is just as bad as too little.
When you are pumping in too much (especially) dense, cold grease; it will push out the inner bearing seal.
As far as the dust cap, when I am topping off the grease, I just want to see movement of grease 'somewhere' out the front of the bearing. I don't want to have the dust cap packed with grease, as all it's going to do is squirt out when it gets hot. The only thing the grease in the dust cap is doing is keeping the outer bearing dry from water that squeaks in.
Sydwayz is offline
Old 02-23-2016 | 10:12 AM
Thanks guys.. That's kind of where I was leaning, just didn't know if grease keeps coming out while driving.
As for cold... It was 76 this weekend and next looks good too! :-)
nailit is offline
Old 02-23-2016 | 10:24 AM
On a new install I do use a thing that I put the bearings in and it pumps the grease through the rollers. In the old days we used to pack them by hand but same idea. This is before you put the bearings on the hub.
Wildman_grafix is offline
Old 02-23-2016 | 10:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Bearing packer:
http://www.northerntool.com/shop/too...dFAhoCDsjw_wcB
https://www.youtube.com/watch?v=n2aiQGD9Fd4 I too use a Bearing Packer every time when packing new bearings.
Sydwayz is offline
Old 02-23-2016 | 11:49 AM
scippy's Avatar
nailit.........Just did some work on my tandem trailer that requires bleeding all the brakes again. Always a hassle doing it alone, but the pump looks lke a one man show. Can you tell me the model pump u used?....Scippy
scippy is offline
Old 02-23-2016 | 07:55 PM
It's was a harbor Freight pneumatic bleeder kit. Only have 1, others are hand pump..
Regarding packing, I usually pack by hand, but I did read with spindle lube, it's not necessary b/c the grease comes from the back. I did try it and of course it works, but I also spin the wheel the entire time I am pumping grease to help NOT blow out the seal in the back.
The holes is actually between the seal and the inner bearing. Never really looked until this time.. 1 lil hole.
nailit is offline
Old 03-06-2016 | 09:18 PM
If not a new install, I would keep pumping until all the old, dirty grease was pumped out. I would basically change the grease and as I recall it would take about 1/2 a tube per wheel. I would also spin the wheel while "changing" the grease and keep wiping the old away with shop rags until it new fresh grease.
Scagburner is offline
Old 03-08-2016 | 06:43 AM
Good video from Dexter:
https://www.youtube.com/watch?v=XT0RKDGgDm8
troper is offline
