What are issues to look for on 29 scarab >
Old 02-24-2016 | 12:38 PM
Default What are issues to look for on 29 scarab
I am going to look at a 97 29 scarab this weekend and am curious what I should keep my eye out for. From browsing forums it sounds like they are known for wet transom/stringers. Is there a way to check this without disrupting the boat. Any other things to look for that are common. Does anyone know a surveyer in Dallas area?
jus491 is offline
Old 02-24-2016 | 02:30 PM
If there are any screws you can take out and stick a small pick in, and if it has Kplanes, loosen the nut on the oil tube and pull the washer back and stick the pick, those holes are large and low. culprits of seeping water also.
class6 is offline
Old 02-24-2016 | 06:42 PM
Thanks for the suggestion I will definitely check that
jus491 is offline
Old 02-29-2016 | 11:19 PM
Mine is going to Northwest Fiberglass in the morning to have a piece of wet wood replaced and wet sanding....Good luck, they are great boats.
SunsationLarry is offline
Old 03-01-2016 | 07:13 AM
hullofjustis's Avatar
Originally Posted by sunsationlarry
mine is going to northwest fiberglass in the morning to have a piece of wet wood replaced and wet sanding....good luck, they are great boats.
what does your 29 run with twin 650hp in it? I had one with a single blown 540 that ran mid 80's. That thing must scoot?
hullofjustis is offline
Old 03-01-2016 | 07:22 AM
[QUOTE=jus491;4407942]I am going to look at a 97 29 scarab this weekend and am curious what I should keep my eye out for. From browsing forums it sounds like they are known for wet transom/stringers. Is there a way to check this without disrupting the boat. Any other things to look for that are common. Does anyone know a surveyer in Dallas area?[/QUOTE
INSPECT THE TRANSOM FOR ROT
