1988 320 EFI injectors? >
Old 03-07-2016 | 10:16 AM
Default 1988 320 EFI injectors?
Hi,
BOAT; I have a 2 1988 mercruiser racing 320 EFI 5.7. in my Formula 272 sr1/ bravo,
I need a manufacturer's part number for the obsoleted injectors?
I want to replace them.
I have read alot on this and other forums but havent got the EXACT part number I can use at the autoparts store to get the correct injectors. I have seen mention they are the same as a porche 928, but no mention of what year? and What exact Model 928.... frustrating
oconnor marine is offline
Old 03-07-2016 | 10:41 AM
member BUP would be the person who can help you.he is the master of oe fuel injection.
mike tkach is offline
Old 03-07-2016 | 12:13 PM
BUP
Thanks Mike for the good words ^^^^^
It would best to replace these with the most current offerings. Those injectors in the 320 from 1987 thru 1989 are very out dated and the spray pattern is not the greatest especially almost from 30 year old injectors - compared to whats on the market now.
I know your engine and have worked on this app before but they are very rare currently and really not many sold back in the day for Merc. alot of times the 320 was matched up with an Alpha SS drive.
Anyways I would need some of your injectors as I would want to flow match to the current offerings. I do not want one injector but say 6 or 8 would be good. I need to get base numbers and go from there to match these up. Thanks John
BUP is offline
Old 03-07-2016 | 12:15 PM
BUP
If you wanted to send me all 16 injectors thats fine to. If so make sure you number them which hole (cylinder) and which engine side they came out of.
BUP is offline
Old 03-07-2016 | 01:03 PM
Thanks for the reply. Im very busy and im sure you are too, unless this is a service? and really was hoping for an off the shelf replacement injector that would perform as well or better than original new ones without having to make a time consuming ordeal for anyone. There has to be an exact replacement that someone has found. Previous threads mention this without really specifying numbers or exact applications
Old 03-07-2016 | 01:19 PM
BUP
I also do fuel injector service and have been for 7 straight years and ONLY with marine stuff. Flow volume, spray patterns and fuel pressures are very important. Sorry I am not going to wing it and throw out a cross injector without testing them (old ones and new) nor want to be responsible for it going by what people say on the net for a replacement. If you work on boats for living as I do to - you know how it is.
Good Luck
BUP is offline
Old 03-07-2016 | 01:24 PM
What is the Bosch PN on the upper plastic part of the injector?
0 280 150 ???
Jeff
hallj is offline
Old 03-08-2016 | 05:07 AM
[QUOTE=hallj;4412699]What is the Bosch PN on the upper plastic part of the injector?
0 280 150 ???
Hi Jeff ,
I'll take a look later. and get back to this thread. Thank you,
Old 03-08-2016 | 05:09 AM
Good Luck
Oh Ok, it is a service . How much do you charge? yes I do have a boat repair shop and respect your professionalism. Thank you
Jim
Old 03-08-2016 | 06:27 AM
dcb
Good Luck
BUP is absolutely right - just went through this with my 575 SCI injectors - searched and found a pn for a supposedly compatible replacement - Dave @MDG was kind enough to flow test it - nope not even close.
dcb is offline
