Which airbags?
There are a whole lot of airbag systems out there and I just don't know enough about them to make a intelligent decision. I will be installing them on a 08 F350. For the most part it is my daily driver. But it is the truck I use to tow the boat. After installing a leveling kit on the frontend I am worried that the trailer weight will drop the a$$end to much. What has been working or not working for you? Thanks Mark
Kelderman offers 2 different options for the rear
Firestone R4TECH
http://www.sdtrucksprings.com/index....ducts_id=16756
Firestone Ride Rite (put over 600,000 trouble free miles on them)
Air lift
Lots of others
Firestone R4TECH
Air lift
Lots of others
Firestone and Air Lift are made in the same factory. (Firestone's)
I have run both with no issues whatsoever. I've had them on 5 different trucks.
If you are installing an air system, make sure you visit www.hornblasters.com
It's the best $800 I've spent on a tow vehicle.
http://www.truckspring.com/products/...5lxxoCilLw_wcB
You have to run air lines into the cab of your truck, but that's really not a big deal.
There are also wireless kits as well, they are not really 'add-on' kits, plus you have to run power and ground; and they are expensive.
http://www.4wheelparts.com/parts/fir...ntrollers.aspx
