4.5 inch stroke crank??? >
Old 09-23-2002 | 12:47 PM
dyno's Avatar
Charter Member #655
Default 4.5 inch stroke crank???
I was on FlatLanders website looking at stroker kits and they list a 4.5 inch stroke for a 454 anyone running one?????it gets you to 525 cubic inch......bigger is better!!!!right????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 09-23-2002 | 01:23 PM
Official OSO boat whore
Doesn't a 4.5" stroke require quite a bit of clearancing?
Cord is offline
Old 09-23-2002 | 01:48 PM
DOCTOR DAVE
you might run into a problem tring to install a 4.5" stroke in a short deck engine, you will need a tall deck 10.200 deck height with a bit of grinding on the pan rails for clearance of the rods. then youll need some .400 long rods and pistons, heck..might as well make it a 572 or 588 for the same money
Old 09-23-2002 | 02:21 PM
cougarman's Avatar
Default 4.5 Stroke
Dyno,
If your trying that in a 9.8 standard deck,
it's to much rod angle.
Some guys do but it's pretty high risk.
10.200 tall deck on the other hand is just
fine. Add a 4.5 bore with that 4.5 crank
and you have a 572 ci.
Cougarman
cougarman is offline
Old 09-23-2002 | 07:34 PM
dyno's Avatar
Charter Member #655
thanks guys guess I'll stay with 4.25 and 496CI......
dyno is offline
Old 09-23-2002 | 11:01 PM
KAAMA's Avatar
A 496" engine isn't too bad for a boat because it runs low RPM's (5500) for it to be unreliable. I have know a few guys who've run them in there offshore boats---even with blowers. I think Doctor Dave even ran a pair at one time in his 35'Cig without any problems.
KAAMA is offline
Old 09-24-2002 | 05:19 AM
dyno's Avatar
Charter Member #655
Mark thanks !!!!I stopped by the shop last night nobody home.....hope things are coming together for you!
dyno is offline
Marginmn
Swap Shop
4
09-10-2008 11:31 AM
The Menace
Ocean Express
4
07-19-2004 04:09 AM
