Baja 302 Bilge Pump Replacement >
Old 03-11-2016 | 10:19 AM
Default Baja 302 Bilge Pump Replacement
Any suggestions on replacing the bilge pump? If my arms were 7' long I might be able to reach it!?
Tips? Tricks? Do I have the pull a manifold to get to it? Pull an engine?
justinp20012500 is offline
Old 03-11-2016 | 10:44 AM
F-2 Speedy's Avatar
Hire a carney ( Circus folk ) I would relocate it unless you want to pull the engine to set it on the pad, its probably in the same place as my 33, right under the pan on the starboard engine the wire on mine went down the center stringer. Good luck, BTW they like cabbage
F-2 Speedy is offline
Old 03-11-2016 | 11:09 PM
I'm moving my bilge pump discharge hose, I was prepared to take the strb engine out to get at everything. After removing the exhaust manifolds from centers ther was enough room to wrk at it without removing engine. It'll b a pain but easier than pulling an engine!
My 2 cents .
rivermonkey is offline
Old 03-14-2016 | 10:19 AM
Thanks for the advice. I'll pick up some astroglide and tie a rope around my waist.
Old 03-14-2016 | 09:40 PM
Good luck with ur personal lubricant
Old 03-18-2016 | 10:17 AM
Everything is better when its lubricated! Everything!!!
Old 03-31-2016 | 11:19 AM
Did it a few weeks ago on mine and used elongated pliars, needlenoses, screwdrivers without issue. 20 min job.
Tractionless is offline
