PCM555 ECU memory error message >
Old 04-09-2016 | 06:08 PM
Does anyone know what "ECU memory error" means on a PCM-555. I sent them off to get reflashed and that is the code I am getting which puts it in guardian mode. Any help would be appreciated on this
joketchum is offline
Old 04-10-2016 | 10:04 AM
BUP
PCM 555 OEM version calibration, ECM Memory Fault code should be #138 which means the memory is corrupted for a fault explanation in turn means the ECM / PCM is bad. Anytime I have seen that code, 100 % of the time, the ECM / PCM was bad.
With that said, I would send it back to whomever flashed it and see what happened along a possible fix or new PCM/ECM'(s).
BUP is offline
Old 04-10-2016 | 01:44 PM
Who relfashed it?
Trash is offline
Old 04-10-2016 | 04:09 PM
BUP
for the triple nickel in the US not many can reflash this (ECM 555 / PCM 555). If I recall only possible 2 or 3 can that are not related with Motorola / Mercruiser.
BUP is offline
Old 04-10-2016 | 08:08 PM
well the ecu's were working when I sent them off and I can put a friends stock ecu's on my boat and it runs fine, so I can only assume that it was the cal that was put on it
Old 04-10-2016 | 09:16 PM
BUP
and out of the very very few who can ever recal these 555's so who did yours ????
BUP is offline
Old 04-10-2016 | 09:27 PM
I don't want to throw any names out here, but if you know the boating industry you know who it possibly could be. I just don't understand how putting a standard performance tune that many people have could make the ECU bad now
Old 04-11-2016 | 11:34 AM
BUP
I hear you and understand. IMO I am totally against sending out PCM 555 and PCM 09 and e controls to get reflashed thru the mail no matter who is doing it and the end user just plugs and plays. Totally against that form of tuning.
BUP is offline
Old 04-11-2016 | 02:00 PM
well they are going back to get looked out. If you have a stock motor and a company develops performance calibrations for that particular stock motor, then it shouldn't be that big of an issue.
Old 04-11-2016 | 03:57 PM
It could have been a bad flash and the files have incorrect parameters or memory address. I'm not sure how similar the architecture is on the 555 vs the older MEFI though.
Trash is offline
