mercuiser 383 stroker header assembly any one used them? >
Old 04-11-2016 | 10:29 AM
Default mercuiser 383 stroker header assembly any one used them?
looking into getting a set of #879288020 #879288019 Mercruiser Headers they are pricey. So just wonder if anyone has had experience using them and anything you can tell me about them. Any noticeable power increase? Is it worth the bang for the buck? Mabey someone has a good deal on a used set. any info be appreciated thanks
http://www.marineengine.com/newparts...m=MER879288019
apex808 is offline
Old 04-11-2016 | 03:53 PM
Unless you spin your motor beyond 6k I would have serious reservations about spending extensive amounts of money on exhaust for a SBC. You will find virtually no well documented information for marine SBC header performance improvements. I believe there is a reason for that....
I have not found stockish (GLM) manifolds to be rpm or performance restrictive below 6000 rpm.
Trash is offline
Old 04-11-2016 | 04:12 PM
That's good info. I would never have thought that however makes sense. Higher hp bbc 500 hp plus tend scavenge and will definitely notice hp gains however their a whole different breed.
Ck on eBay for some deals. I see some good deals on them., I have a sbc boat also but if I was going to use it much I'd defiantly have some exhaust on it just because. Lol.
Remember with those exhaust u linked to need tails also. I'm sure u knew that but just in case.
getrdunn is offline
Old 04-11-2016 | 04:49 PM
Yea that makes sense just be more of a cool factor lol. I have threw hull tips on it already just wanna add some bling Mabey just some risers Crome ones haha! What ya think do you guys know of any that bolt to the stock cast headers?? They are dry joint...
apex808 is offline
Old 04-11-2016 | 05:08 PM
the stock merc exhaust can handle 375 or so hp. a small block has to be pretty special to not be satisfied with that. the chrome or stainless risers cost about 800 bucks a pair new. worth no more hp. I know. get merc aluminum risers and polish them...
dereknkathy is offline
Old 04-11-2016 | 05:19 PM
Just out of curiosity what kind of power is your 383. I built one of those for my 73z28 in high school and that engine was incredible. It was 435 hp but 10:1 compression. Torker dual plane and comp 292 magnum cam with closed chamber double hump gm heads. Awesome engine. I know what your up to. And hey that's what it's all about. Having fun and going fast with some cool factor. Bling bling bling. Lol. It's fun regardless. At least your doing what you enjoy and staying out of trouble.
getrdunn is offline
Old 04-11-2016 | 05:44 PM
It's built buy mercruiser saposed to be 350hp I have it in a 1990 wellcraft nova with bravo one drive it skates at 55mph @4900 rpm full tank and two people at the moment running 19p 3 blade cleaver
apex808 is offline
Old 04-11-2016 | 06:26 PM
SB
350hp totally fine with GLM's or Eddies or Revolution. Some may argue stock manifolds. Thru hull though of course.
SB is offline
