gen 6 head gasket
Looking for some info here, Redoing the heads on my 500efi. What thickness gasket should be used for stock application? My current bore is 4.45" Anyone have a cometic or felpro part #?
fel pro 1047,it is a composit gasket with a compressed thickness of .039.the gasket bore is 4.540.the bore on a 502 is 4.466 so you can not have a 4.450 bore.you don,t need a mls gasket and unless you resurface the head&block deck i don,t reccomend a mls gasket.
This is actually a thread I'd like to piggy back on. I will also be ordering new head gaskets. Adding 2.3l sidemount whipples to 502 mag mpis. I was told to go cometic. Many different thicknesses. The block is brand new and the heads will be gone through at machine shop. Wondering how I would pick a thickness.
what cam are you going to run?
