What is the best place to mount transducer on Cat?
I am trying to figure out the best place to mount a transducer on a 30' Spectre Cat. I want to use an internal transducer. I don't want anything hanging off the back of the boat. I understand they don't work very good shooting through a core hull. Where is everyone mounting them on their Cats?
You think even the very rearward part of the hull next to the transom wouldnt work? Thats where i would mount it.
Try calling skater or one of the other cat builders... id be more comfortable cutting a hole in the coring back there too as that entire area is very strong... rm
I talked to Jay Pilini and he said the bottom is cored and would have to cut a portion out and epoxy it in. I am not sure I want to do that. I am going to look at possibilities of mounting on the transom. With all the steps in the hull I doubt I would get a reading at speed like everyone has said. I may just not even worry about a transducer. The new Garmin I am installing has a pretty neat 3D down view, so that is the reason for the transducer.
We are on our 3rd different way of mounting a transducer. This time DCB did a true thru-hull with a brass fitting. I'll still lose depth readings probably above 35-45 mph but that's also what gps/charts are for.
