Trim pump help....
Old 04-25-2016 | 08:23 PM
Default Trim pump help....
I installed a new SEI trimp pump last year and worked great.... BUT went to prep the boat for this season and the pump stopped working... Of course, I am 3 weeks out of warranty
When I hit the trim switch up or down, I hear clicking from solenoid but the pump does not run....
Is this as simple as replacing the solenoid or has the pump taken a crap on me??
Thanks in advance...
Chris
cdaniel525 is offline
Old 04-25-2016 | 08:31 PM
Corrosion on the terminals, or bad connection. Jumper across the solenoid with heavy gauge wire to see if the pump motor is working.
blaquebaja is offline
Old 04-25-2016 | 08:52 PM
Thanks for the reply... I'll clean all the connections tomorrow and give the jumper wire a shot as well...
Thanks again
Old 04-25-2016 | 10:03 PM
c_deezy's Avatar
If that doesn't work, pull the pump motor off and see if you got some rust/corrosion on the output shaft.
I had one do that a couple years ago, broke it down, sprayed some penetrating lube on and spun it by hand, put it back together and good to go.
c_deezy is offline
Old 04-26-2016 | 07:57 AM
Also check your manual or call CS for a minimum voltage requirement to operate the pump and solenoids. I have a Boat Leveler Co. Pump that requires a min. Of 12.7 volts. If you're not above the minimum due to storage, weak batteries, etc. it may be as simple as cranking it up.
Tractionless is offline
Old 04-26-2016 | 07:26 PM
I actually tried that as well, had it running and alternator working good but no luck... Batteries were fresh off chargers as well....
Didn't get a chance to mess with the pump today... Weather was ****, hope to get to it tomorrow!
