Power steering pump seal kit
My pump has a slow leak. I believe it's the pump/reservoir seal. Found this kit:
http://www.ebay.com/itm/SAGINAW-POWE...tRroLu&vxp=mtr
Anyone know if it would work?
It's for my 1990 Fountain.
the pressure regulator is different(big nut on rear with valve and spring under), seal kit will work, main pump the same, was told but I never verfyed that they used a bearing instead of a bushing for the marine pumps and they were done by AGR
