ISO rubber feet for Fountain bench seat >
Old 05-01-2016 | 01:21 PM
Default ISO rubber feet for Fountain bench seat
All but two of the rubber feet that are attached to the under side of the bench seat on my 2000 Fountain are either missing or broken and I have not been able to locate any. I need to get at least 10. Because with out them the screws are tearing the gel coat up. They are one inch in diameter and 3/8" thick with a stepped hole in the center for the screw. Any leads would be appreciated.
fordf350 is offline
Old 05-01-2016 | 02:26 PM
I found some at local hardware store . They were white in color same size
gofisch is offline
Old 05-01-2016 | 05:41 PM
I checked with Lowes and West Marine with no luck.
fordf350 is offline
Old 05-01-2016 | 08:38 PM
I found mine locally also, maybe Home Depot? I'll check my bin to see if I have the MFG info.
**edit: I think these are the right feet
http://www.homedepot.com/p/Everbilt-...9131/203661032
Ryan
Ballistic Beak is offline
Old 05-02-2016 | 02:04 AM
I'm sure http://www.mcmaster.com/# will have something that will work
Griff is offline
Old 05-03-2016 | 10:10 AM
Thanks everyone. But it looks like I found them on E-bay. They are like the feet on the bottom of electronics. Hope they work.
fordf350 is offline
