Can you rebuild a HP500 power steering pump
Took the Talon our yesterday for shake down run, noticed power steering slow to respond, checked it out, and I can pull the pulley shaft out about1/32 inch, push in back in, bearing problem?
Everything is for sale @ a certain $$
pump could be down on pressure, yes can be rebuilt, but you would be better off replacing it, you can use a one from a truck, just exchange the pressure regulator and spring(large nut where pressure line attaches) with your old pump
Good to know, thanks
