My V Drive is heavier than yours >
Old 05-03-2016 | 09:20 AM
Default My V Drive is heavier than yours
skipping that stupid ad block
f_inscreenname is offline
Old 05-03-2016 | 09:21 AM
My V-drive is heavier then yours.
What you all are looking at is a 1967 Casale, C-1000 out of my race boat. All 64lbs of it. Makes my HallCraft in my Biesemeyer look like a paper weight. It is basically a (aluminum) V Drive but the bottom shaft that connects to the prop shaft actually goes all the way through the V Drive and out the back side to connect to another motor. That motor is basically a direct drive and the second motor is attached to the top shaft of the V Drive like a normal set up. Two motors into one V Drive to one prop. Saved about 4 to 6 mph from running a second set of running gear.
Old 05-03-2016 | 09:58 AM
So a pic of the two motor beast?
Wildman_grafix is offline
Old 05-03-2016 | 10:05 AM
Any chance I get I'll post one.
Old 05-04-2016 | 02:01 PM
Still the Absolute Coolest Boat on this site.
Think Brownie hit his head a little too Hard one too many times to dream up that Monstrosity.
tommymonza is offline
Old 05-04-2016 | 03:24 PM
Do you know where to get two more of those? Don't need the two motor option though. Used of course.
Jeff
hallj is offline
Old 05-04-2016 | 03:26 PM
Different world back then. Like Nascar today. Spend, build and do anything that will give you the tiniest advantage. One prop instead of two with the same power...advantage. Especially when you go 250 miles that way and another 250 back.
Old 05-04-2016 | 03:29 PM
Jeff
Are you looking for V Drives?
Old 05-04-2016 | 05:18 PM
Yes sir!
Jeff
hallj is offline
