Volvo Penta Duoprop - C7 - HP/Torque & top end >
Old 05-04-2016 | 11:14 PM
Default Volvo Penta Duoprop - C7 - HP/Torque & top end
Anybody ever run a VP duoprop C7 (SS) prop? I am curious what it took to spin that thing and what the top end (speed) on this was for you.
Also, any idea why the front blade is so much larger than the rear blade? i've never before noticed this in a dual blade configuration.
Thanks!
- scott -
scottgjerdingen is offline
Old 05-07-2016 | 08:17 AM
madbouyz's Avatar
I'm running a V/P 5.7 (280 pshp) with a DPS-a unit that has an F7 propset . The gears are 1.95:1 . The boat is a 19' 66 Donzi
I had the propset scanned when I got them as the shipper packed them poorly for freighting and they got slightly damaged . It turns out that they're a tick under 26'' pitch.
I'm going to go out on a limb here and guess that in Volvo's mysterious nomenclature the first letter denotes the design series (and thusly which drive it fits on) and the number denotes pitch . Assuming that , yours are about 26'' pitch also .
I only had a chance to test briefly but I believe that this is the absolute correct size prop set for my application judging by the direction that the rpm's were heading when I momentarily booted it . On my engine that would be 5000 rpm max .
The performance is pretty stunning to say the least .
On the Merc B3s the front prop is quite a bit larger then the rear also so I guess they've learned something about the way these things work . On mine the rear prop more resembles a cleaver .
madbouyz is offline
Old 05-14-2016 | 09:18 AM
My U-19 Four Winns (When Four Winns owned Donzi) with a modified 5.8EFi runs F9 props, 1.95 gears with nosecone 4600RPM to 72MPH. My outdrive service lists "D" props as aluminum and "F" props as Stainless. I have not seen a "C" designated prop.
Taboma is offline
Old 05-14-2016 | 11:07 AM
madbouyz's Avatar
http://www.volvopenta.com/SiteCollec...er%20Guide.pdf
Doesn't appear to be any 'C' designation props there ..
Oops , amazing what you can see when you read something for the 3rd time . I now see a 'C' series prop . They're for the 280 and 290 Dp units .
madbouyz is offline
Old 05-14-2016 | 11:11 AM
I ended up picking up an F7, it seemed to be the highest pitch available. Now the boat just sits waiting to have some work done to it, hopefully I will have it in the water by end of month and I can report back on how it worked out.
Old 05-14-2016 | 11:16 AM
madbouyz's Avatar
What is the lower unit you're using ?
OK , refer to my edited post above . Will an 'F' series propset fit on a 280/290 drive ?
madbouyz is offline
Old 05-14-2016 | 02:42 PM
I have F9's. They are available.
Taboma is offline
