msd?
Old 05-05-2016 | 08:11 AM
Default msd?
Does anybody have any info on replacing a 6m box with a GM 4 pin module. Also would this work with a crank trigger.
fbc25el is offline
Old 05-06-2016 | 05:41 AM
just replace the whole deal with a HP hei remove the vac advance(kit made to block off) get the 2 correct wire connectors and roll on..
ezstriper is offline
Old 05-06-2016 | 05:56 AM
Wobble's Avatar
SORE MEMBER
I misunderstood, you want to delete a 6m box?
this thread http://www.offshoreonly.com/forums/g...placement.html
Wobble is offline
Old 05-06-2016 | 08:07 AM
I heard somewhere that you could take a 4 pin module D1906 to replace a msd box. They say it makes a good back up.
fbc25el is offline
Old 05-06-2016 | 08:36 AM
Wobble's Avatar
SORE MEMBER
if you can mount it in or on a good metal surface because it needs a heat sink then yes it could replace a box, crank trigger would replace the wires that come from dist magnetic pickup assuming the crank pickup has a compatible signal (which it normally would)
or you can just carry a spare box
Wobble is offline
Old 05-06-2016 | 08:39 AM
Wally's Avatar
Were doomed!
This may be what your thinking about
-Wally
Wally is offline
Old 05-06-2016 | 08:58 AM
Yes, thanks.
fbc25el is offline
