whats the best way to trim both drives with one switch? >
Old 05-06-2016 | 07:47 AM
Default whats the best way to trim both drives with one switch?
1988 mercruiser ; whats the best way to trim both drives with one switch? im thinking have a separate switch with both wired to it then tweek them individually because they trim slightly different speeds.... what do you think?
thanks
oconnor marine is offline
Old 05-06-2016 | 08:10 AM
Wally's Avatar
Were doomed!
yes...third switch with diodes so the individual switch don't back feed the other when doing one at a a time...
-Wally
Wally is offline
Old 05-06-2016 | 09:54 AM
cool thanks
Where do I get a switch with Diodes?
Old 05-06-2016 | 10:09 AM
14 apache's Avatar
They also make double pole switches than you don't need diodes.
14 apache is offline
Old 05-06-2016 | 10:40 AM
Wally's Avatar
Were doomed!
Yes your right! i didnt think about that! that would be a simpler solution....but as far as switches go you can get them just about any marine supply store or online and diodes you can get from a local radio shack if there are any still around....
-Wally
Wally is offline
Old 05-06-2016 | 10:41 AM
SB
thanks
You looking for on the throttle switch or on the dash ?
SB is offline
Old 05-06-2016 | 11:20 AM
VoodooRob's Avatar
Put 2 switches on the throttles 1 for drives and 1 for tabs, did it last year on our boat and its one of the best improvements I've done so far.
[ATTACH=CONFIG]555073[/ATTACH]
Attached Thumbnails whats the best way to trim both drives with one switch?-20150603_184427.jpg
VoodooRob is offline
Old 05-06-2016 | 11:27 AM
Where did you get those throttle switches?
Mr Maine is offline
Old 05-06-2016 | 11:30 AM
VoodooRob's Avatar
Livorsi sells the switch kit complete with instructions, you have to call in and ask for it.
Old 05-06-2016 | 06:33 PM
I did the same thing. It's really nice as you get on plane.
Wildman_grafix is offline
