2.5 Trim Ram Technical Question >
Old 09-26-2002 | 07:27 AM
Question 2.5 Trim Ram Technical Question
Okay guys, I need some help. Last night when changing gear oil I found a leak in the trimram/cylinder portion of one motor. Upon further inspection it turns out the plate that the trim piston passes through, that screw into the top of the trim cylinder, unscrewed. I did not have the proper tool to tighten this collar and subsequently butchered it up pretty good! I got it as tight as I could, and hate to buy a whole new unit (probably big dollars ) if this can just be repaired. My thought was this. It appears as if it is leaking from the out seal/edge. Again, I got it as tight as I could. I was thinking of using JB WELD to seal the outside perimeter. If this doesn't work then I guess I need a new unit. Any thoughts? My main goal is to refill the trim pump with oil and get me through next weekends HOT TOTTIE run and a run on Lake George the following weekend. Then I have all winter to replace it or do what is necessary. ANy help would be greatly appreciated.
Thanks.
Shane
Shane is offline
Old 09-26-2002 | 08:26 AM
HELP?
Shane is offline
Old 09-26-2002 | 09:50 AM
GRH
Try General Hydrolics in Johnstown... 762-3712.... if its hydrolic.. he can fix it!
Old 09-26-2002 | 09:51 AM
Thanks Gary!
Shane is offline
Old 09-26-2002 | 10:15 AM
GRH
You're Welcome... you might try Albany Hydrolics.... thier closer... i used the guy in Johnstown a couple times... hole in the wall shop, but the guy has everything known to man for hydrolic equipment... he rebuilt a K-Plane pump for me while I waited one day! nice guy.... charged me $10.... .... Good luck!
saulesses
Prop Talk
5
06-20-2007 07:48 AM
fountain27ho496
9
03-30-2007 10:49 PM
racer-x6
9
03-10-2005 11:03 PM
SeaWeasel
3
03-14-2004 09:23 AM
In2Deep
04-23-2002 08:00 PM
