Hydro hoist tube ?
Old 05-08-2016 | 05:59 PM
Default Hydro hoist tube ?
So I moved my lift back to my dock last weekend and got a call during the week that the starboard stern tube was loosing air. I went up dropped the boat in the water and later looked at it this weekend. I noticed that the tube may have shifted and spun in and forward. Is there an easy way to fix it with out pulling it out and resting it? Any help would be grate thanks.
1989mach1 is offline
Old 05-08-2016 | 06:33 PM
Also checked the valves and no leaks air is leaking from the hole in the bottom of the tube.
Old 05-08-2016 | 09:18 PM
Only one thing will cause this to happen and that is an air leak somewhere. Check for cracks on the tube/tank and that the valve is able to close all the way.
If there is a crack in the tank it can be repaired easily.
phil_p999 is offline
Old 05-09-2016 | 01:14 PM
Ran-Dom 32's Avatar
I had a tube rotate on me after a bad storm, with the boat off & some big ratchet straps you should be able to loosen the fasteners & get it back to where it belongs, just have to be creative
Ran-Dom 32 is offline
Old 05-09-2016 | 01:44 PM
BMBoyer's Avatar
I would think it is easier to rotate the tank at near neutral buoyancy so just have enough air in to have the tank barely break the surface. Keep the up pressure to a minimum to reduce friction with the saddle, ratchet strap a pry bar or 2x4 to the tank, loosen saddle straps and rotate. You should be able to walk it fore and aft and see the 12 o'clock position on the fill connection on top, that should put the displacement holes at the 6 o'clock.
Sounds like it is an older Hydro Hoist with round (probably fiberglass) tanks or are you just saying hydro hoist as a generic and it is another manufacturer?
BMBoyer is offline
Old 05-09-2016 | 02:04 PM
It is the older round tubes. Side tie b model
Old 05-09-2016 | 02:09 PM
I tryed to just spin it with 2 ropes one front and one back but couldn't get it. I will have to try the straps with a bord. I did loosen the bottom straps but maybe not enough in fear of loosing hardware. Thanks for the tips guys. This is why I love this site
Old 05-09-2016 | 02:11 PM
Ran-Dom 32's Avatar
basically that's what I did, as BM described , but while the hoist was aired up.. & mine is a side tie as well
Old 05-09-2016 | 02:15 PM
Cool thanks
Old 05-09-2016 | 02:16 PM
Can't wate to get up there and try it again this weekend. My boat is down in the water for now and it is killing me knowing that lol
