Wet slip
Old 05-12-2016 | 07:26 AM
Default Wet slip
Does anyone here wet-slip their gofast boat for the whole season? Using anything for the bottom?
chrisvr6 is offline
Old 05-12-2016 | 07:36 AM
If your as anal as most of us...you won't be happy about how dirty and stained the bottom gets. Pull it every couple of weeks and clean with Slimy Grimey. Bottom painthe will slow the boat and hurt value.
Padraig
Padraig is offline
Old 05-12-2016 | 07:42 AM
Yeah i don't care about dirty as much as blisters and whatnot. I want to buy a fast boat but also want the harbor life. No lifts in chicago harbors either. I did it with an unprotected bottom last year and everything came off the bottom and no blisters either though. So i don't know.
chrisvr6 is offline
Old 05-12-2016 | 08:58 AM
I do but in extremely clean and cold water. I also have a epoxy barrier coat on the hull bottom. Occasionally get the snorkel gear out and scrub the bottom clean.
Interceptor is offline
Old 05-12-2016 | 09:03 AM
Yeah I'm in lake michigan (chicago). Super clean and cold as well. Everything powerwashed right off with an electric powerwasher after 6 months being in the water. I did use colinite fleetwax on it prior to wet slipping. Which epoxy barrier coat did you use and what kinda boat?
chrisvr6 is offline
Old 05-12-2016 | 09:12 AM
When I did mine in CA I had a diver scrub the bottom every month. Worked very well.
GLENAMY 242SS is offline
Old 05-12-2016 | 09:30 AM
What kinda boat? With bottom paint?
chrisvr6 is offline
Old 05-12-2016 | 09:47 AM
Might want to do some searching and see if your boat is prone to getting blisters.
Padraig
Padraig is offline
Old 05-12-2016 | 09:53 AM
Formula 272 LS and no paint. Now I did put on the trailer about mid season and end of season to really clean the bottom. The diver keeps it tidy and critter free but not real clean.
Old 05-12-2016 | 10:14 AM
Oh i assumed all boats blister in a matter of time.
chrisvr6 is offline
