would you notice 100 more ft.lb. torque
in a single engine boat (same stroke, same rpm) lets say hp and torque curves are similar, w/ the exception one engine is up a hundred
would you notice the engine that was up 100
plan is stay inside design limits of drive. specifically 500 torque w/ operating range 5500-6000, another member i spoke w/ said 5000-5500 would be better
drive is b1 sweptback, it's at mr. gadgets getting some mods, setup, and drilled and tapped so i can run the oil thru a cooler.
first or second pump in the link, mocal continuous duty bronze gears. (open to suggestions on pump)
http://97.74.32.155/files/pump.pdf
http://www.summitracing.com/parts/der-25049/overview/
http://www.hardin-marine.com/p-13581...il-cooler.aspx
