1996 27sr1 >
1996 27sr1
1996 27sr1
Old 05-17-2016 | 09:43 AM
JDB1981's Avatar
Default 1996 27sr1
I have a 27 sr1 I am putting about 625 hp in it I have a bravo with 1:50 gear ratio what pitch prop do you'll think would be best I was figuring a 26p bravo what is you'll a opinion
JDB1981 is offline
Old 05-17-2016 | 12:30 PM
Many moons ago I had a 2000/271 Fastech with about the same HP and gear ratio and that's the prop I ran.
Rattlesnake Jake is offline
Old 05-17-2016 | 02:15 PM
JDB1981's Avatar
JDB1981 is offline
Old 05-17-2016 | 03:54 PM
JDB1981's Avatar
What mph do you think my boat will run with it having no steps
JDB1981 is offline
Old 05-18-2016 | 06:00 PM
Hi
I am far from shure what kind of speed you will get...
I have a friend at Lake Norman with the same boat as you 496 special version 600 + hp Arround 72 mph...
I have a 271 Sr1 with a 496 HO Bravo XR 62 mph GPS so far with a Mirage plus 23 :-)
And then you have this article :
https://books.google.no/books?id=R0P...epage&q&f=true
Please let us know your results ;-)
Monaco20 is offline
Old 05-19-2016 | 09:26 AM
at what Wide open throttle rpm range is that motor?
oconnor marine is offline
Old 05-19-2016 | 01:38 PM
JDB1981's Avatar
5400 to 5600 rpm
JDB1981 is offline
Old 05-20-2016 | 01:48 PM
I have a friend that has that setup. Running 26p Revolution getting 71mph.
GFwannabe is offline
Old 05-20-2016 | 02:36 PM
The last post in this thread were my results... And noticing your location, on the same stretch of water you'll be using.
http://www.offshoreonly.com/forums/f...ml#post3294892
mosport1 is offline
Old 05-20-2016 | 03:18 PM
I think under perfect conditions and with the correct prop, and 625 hp 74/75 mph should be possible.
You have 200 hp more then me, my 62 mph was with 2 persons and 3/4 fuel tank and kind of flat water.
I am sure I will reach 63 mph under perfect conditions ....
Monaco20 is offline
