Anyone Have Dyno Sheet For Stock 525? >
Old 05-18-2016 | 08:47 PM
Default Anyone Have Dyno Sheet For Stock 525?
would like to see hp and torque curves. See where the most power is. I've been told to run mine near 5,400 for max hp.
thirdchildhood is offline
Old 05-19-2016 | 05:31 AM
Dave M's Avatar
Veteran: Navy
There was a post on Faceboook about the 525efi rev limiter. I thought it was 5400 but others were saying 5250. I know I had mine north of 5250 a few times.
Dave M is offline
Old 05-19-2016 | 06:12 AM
It's 5,400. The Mercury service manual says max normal operating range is 5,200 with limiter kicking in at 5,400. It sure feels like the power is still building over 5,200.
Old 05-19-2016 | 09:06 AM
Mine spin to 5350 no problem.
RT930turbo is offline
Old 05-19-2016 | 09:54 AM
jbraun2828's Avatar
5250 is the soft limiter and the light will start blinking but no power loss. 5400 is the hard limited and will start pulling timing if you hit it.
jbraun2828 is offline
Old 05-19-2016 | 12:14 PM
JIMKID Motorsports's Avatar
i think i have a dyno sheet for one i will have to look
JIMKID Motorsports is offline
Old 05-19-2016 | 12:48 PM
http://www.offshoreonly.com/forums/g...orsepower.html
92nsx is offline
Old 05-22-2016 | 03:38 PM
I get a beeper warning with no power loss so that must start at 5250.
That's perfect! Thanks much. I'll print that out.
Old 05-22-2016 | 04:14 PM
Wait. I was thinking that was 567 hp! The 525 has been said to make about 540 hp. That dyno pull shows 467 max hp @ 5,300 at the prop. Does the drive real suck up 72 hp?
Old 05-22-2016 | 08:12 PM
Whipple,,,and raylar,,,'had a good bout,,,,,over the 525
TWIN-SPINS is offline
