Carb size
I'm going to test soon with wide band, but what are thoughts on an 800 dp holley? Enough carb?
.04 over 454, 462ci
Victor junior
308 dart iron eagles, ferrea valves, 8205sp springs
Cam 231 235 and .63 lift
9.2 compression
Bore notched cylinders to match head
Gil exhaust
Looking for input on the difference to say a 850, 950 etc
.04 over 454, 462ci
Victor junior
9.2 compression
Gil exhaust
800 is enough carb for your engine. I had pro systems build me a carb for an engine that probably made a touch more power than your combo. They used a Holley HP950 which flowed 830 cfm's.
800 will work but imo the 850 will make more power.i tried 3 different carbs on a similar build,750 holley,850 holley and 850 barry grant demon.the bg850 made the most hp but the holley 850 made 3 less hp but 15 more lbs torque,the engine was for a street car so it got the holley 850.
