32p x 18"+ dia. 4 blade merc props - LH & RH >
Old 05-23-2016 | 07:52 AM
Default 32p x 18"+ dia. 4 blade merc props - LH & RH
Looking for 18" diameter or bigger props w/ 32 pitch labbed - 4 blade cleavers
I have 32p x 17.5" now, have troubles getting on plane. Would like to try before I buy, will send deposit and pay for all shipping.
frickstyle is offline
Old 05-31-2016 | 09:56 AM
There are quite a few 4 blades on ebay right now
JRider is offline
Old 05-31-2016 | 09:57 AM
I have 32 x 16.25 that I would sell
JRider is offline
Old 05-31-2016 | 10:32 AM
If he's having trouble with 17.5", 16.25 will be impossible
Unlimited jd is offline
Old 05-31-2016 | 02:25 PM
FUNNY, i PUT THE 17.5" X 30P ON YESTERDAY AND IT POPS RIGHT UP ON PLANE AT 2800-3000RPM
Old 05-31-2016 | 04:29 PM
Like I said, its not always about "diameter" for getting on plane. If the prop's blades cant hold water, they cant hold water, and they just blow out. Doesnt matter if they are 16'', or 18''. I've been thru this stuff with #4 and #5 boats quite a few times now. I've seen ****tty 16 3/4 four blades, plane better than 17.5"x28 five blades. Ive had 3 blades get me on plane very well, where some 4 blades of equal diameter, didnt get on plane at all.
MILD THUNDER is offline
Old 06-01-2016 | 07:18 AM
Yes, I remember Dan mentioning the "cupping" of the blade played a huge factor when he finally figured it out. Problem is, damn near impossible to tell that when you are buying them second hand over the internet, unless it's from someone like BBlades that can tell you they have "cup".
I've already spend almost $6K on props, gets real expensive to "test" to see what works. I really want a 17.5"-32 pitch that will work and get me on plane, The boat seems to like 32p a lot, and the cruise speed with 32s is right where I want it. I doubt it could push 34s, but I could always change pulleys and up the anty......
Please let me know if you come across what I'm looking for - 17.5" dia x 32pitch 4 blade with "cup", or stock units that I can send out to have some work done on them. The 32s I have are already labbed and too thin to work the blades.
