Anybody used one of these? >
Old 05-29-2016 | 08:53 PM
seafordguy's Avatar
Default Anybody used one of these?
Anyone used one of these? My boat stays on a lift but even with the cover on I get rain in through the vents, so I have to climb down the back of the boat every time like a chimpanzee and pull the plug.....
I'd put the real plug in if I was overnighting somewhere, but does anyone have any experience with one of these?
http://www.marineengine.com/products...php?in=3671746
seafordguy is offline
Old 05-29-2016 | 09:17 PM
Our boat is on a lift with a lift cover. Being anal I put the snap on cover each night. I never have gotten water in the vents that put water in the bilge. The product you describe sound pretty good and if you are having some issues it sounds like a solution
3pointstar
3pointstar is offline
Old 05-30-2016 | 12:08 AM
I installed one on our boat..
It would get clogged up with the smallest amount of debris when trying to drain water from the bilge
Finally got fed up and took a chisel to it and took out the check ball..
Doug
Boatally Insane is offline
Old 05-30-2016 | 06:07 AM
Doesn't look like you can run an oil drain hose through it.
thirdchildhood is offline
Old 05-30-2016 | 08:07 AM
First world problems....
turbofox54 is offline
Old 05-30-2016 | 08:10 AM
Doug
So with no check ball does that mean the boat sinks everytime you put it in the water?
Jupiter Sunsation is offline
Old 05-30-2016 | 08:22 AM
The struggle is real ya'll...
Jay Gadsby is offline
Old 05-30-2016 | 08:37 AM
seafordguy's Avatar
3pointstar
I always put the cover on, but the vents on the hatch are below the cover on a cafe so rain gets in......
That was my biggest concern. The dirt clogging it and then me enough water getting in to agitate me. I can't stand water in the bilge.....
Doug
I have oil drain hoses on the oil pan that I can just drop the hose and pump out with a drill, but I take he motors out every winter....
. Hey man - saw your boat in CL. Did you decide to off it?
Old 05-30-2016 | 08:40 AM
It's up there but no real hits on it so either I'll part it out or finish it eventually. Already priced below part out value so not going any lower.
