#4 speed master studs, >
Old 06-02-2016 | 08:27 PM
Default #4 speed master studs,
removing 2" spacer and need standard studs for two drives,
Moxy
Moxy is offline
Old 06-02-2016 | 09:11 PM
14 apache's Avatar
Make spacers up to go under head of nut. I dig the injection that's what I run.
14 apache is offline
Old 06-03-2016 | 05:52 AM
pretty sure it doesn't work that way, studs appear to be way to long
Moxy
Moxy is offline
Old 06-03-2016 | 06:50 PM
Team Archer's Avatar
you cant do that with number 4s it only works on number 6s I have a box full of studs if you give me the length I will check for you.
Team Archer is offline
Old 06-04-2016 | 06:51 AM
Thanks, I have no idea of the stud length, I haven't removed the lowers yet? wont be until I have the studs, ill see if I can source a parts list for the #lV's and ill let you know
Moxy is offline
Old 06-04-2016 | 07:47 AM
http://www.marinepowerservice.com/Bo...ngine%20Parts/
MILD THUNDER is offline
Old 06-04-2016 | 09:38 AM
Sick Stinger's Avatar
Brotherhood #1
take 1 out -2 inches from it. go to a machine shop have them cut you X amount.
Sick Stinger is offline
Old 06-04-2016 | 10:00 AM
Only prob is if he wants to put spacers back in, hes back to square 1 again
Old 06-04-2016 | 10:22 AM
ya don't want to limit my options just yet, drives are 2" below bottom, PO had 3 blades and a hell of a time planning boat, 4 blades work excellent and want to see if I can run drives higher
Moxy
Moxy is offline
Old 06-04-2016 | 10:24 AM
[QUOTE=MILD THUNDER;4445927][url]http://www.marinepowerservice.com/BoatingStore/lookup_parts_mercyear2.cfm/coll_style/04/pickModel/SSM3/pickDrive/0/index_nbr/932/block_nbr/18/modNum/71501016/Doc_Part_nbr/PMC
Thanks for the info, I don't know if im out of touch but $20.00 for a stainless stud seem outrageous, does anyone know the specs,
Moxy
Moxy is offline
