Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
Lead under the bow >
Lead under the bow
Lead under the bow
Old 06-12-2016 | 03:37 AM
Default Lead under the bow
I can say that I have finally solved an old problem I had on my Starfire
I installed with a simple but efficient assembly lead that you can see in the attached pics
Attached Thumbnails Lead under the bow-image.jpg   Lead under the bow-image.jpg   Lead under the bow-image.jpg
giocariello@gmai is offline
Old 06-13-2016 | 06:54 PM
Gio,
Have you tried 4 blade props?
Will you be in Viareggio for the big show?
Jeff
hallj is offline
Old 06-14-2016 | 01:31 AM
Originally Posted by hallj
Gio,
Jeff
Never tried but i have to do it,although i think i'm not as fast as with three
I'm planning to go to Viareggio but without boat
Hope to see you there
Old 06-14-2016 | 11:55 AM
bigboat28's Avatar
How many lbs of lead did you put up in the bow?
bigboat28 is offline
Old 06-14-2016 | 12:16 PM
I'm guessing Gio works in Kilograms.
Jeff
hallj is offline
Old 06-14-2016 | 06:09 PM
I put 300 lbs,as about 140 kg,enough to balance add big block weigh
Old 06-14-2016 | 09:51 PM
Have you talked to Giancarlo?
Has he found a new boat yet?
Jeff
hallj is offline
Old 06-15-2016 | 01:22 AM
Jeff
I haven't spoken with him about the 27 but he's still looking for
Old 06-16-2016 | 06:38 AM
Wow! 300lbs?! That seems like a lot of weight to me, how far forward is it. I hope that wood base is fiberglassed in well to hold that weight.
MDonziM is offline
Old 06-16-2016 | 07:54 AM
My Starfire came with two fuel tanks only and miss weight under bow than others
