Trim solenoid question???? >
Old 06-12-2016 | 04:37 PM
Default Trim solenoid question????
Hey all,
Question,
Last year we noticed when we would launch our boat that sometimes the out drive wouldn't lower right away, we would kind of toggle the switch a few times then it would start working.
Today I was doing a few maintainence checks and had it idling in my driveway.
I once again tried to lower the drive and while it balked it did lower...I ran engine then tried to raise it, it would not even try to raise and even while I was toggling it to try to get it to start it would act like it tried then immediately stop, by this time my outdrive was almost touching concrete.
I tricked it by switching out the lines from the pump and got it to raise but now of course that I switched the lines it won't go down.
The question is, do you think my trim solenoid is shot or the whole pump?
Or something else?
I checked/replaced the switches up on the console so I know that isn't the issue but thinking in my mind the solenoid.
Help
Tom272Baja is offline
Old 06-12-2016 | 04:39 PM
Oh yeah, the pump has SAE J1171 on it, it's the same boat as described in my avatar.
Old 06-12-2016 | 05:23 PM
Sounds more like a bad switch, but it sounds like you sorted that out. I replace the solenoids often as they're cheap and easy to do and burn out often. The trim limit switches may be going out but you can bypass them down by the pump to see. There are so many different switches on that system it's hard to tell.
Baja Rooster is offline
Old 06-12-2016 | 06:10 PM
Yeah that's true. Wish it was a bit much more simple.
Lol
Old 06-12-2016 | 07:00 PM
Trim limit switch only has effect on "UP" operation, has NO effect on down.
GLENAMY 242SS is offline
Old 06-13-2016 | 08:20 AM
If the pump is not running, change the solenoids. IF the pump is running with no motion then bleed air..
Pismo10 is offline
Old 06-13-2016 | 01:12 PM
Ok, I replaced both solenoids with two brand new ones, now it will go down with authority but again will not go up.
Should I start looking at wires or what?
If the pump motor dies will it die period or act as mine is acting? Only going one direction?
Old 06-13-2016 | 01:27 PM
Quite possibly a bad trim limit switch which is easy to bypass as the the wires are right by the pump. Google is your friend on doing that. If that's not the problem then it must be up in the dash switches.
Old 06-13-2016 | 01:34 PM
The weird thing is last year I replaced the trim limit switches and just yesterday the switch on the dash.
I guess that's possible one is bad.
Thanks for the help
Old 06-13-2016 | 01:37 PM
Do not use Sierra as their electronics are junk. My trim switch never worked right and quit after about ten hours of use.
