Bleeding Air from my hydraulic steering >
Old 06-14-2016 | 10:56 AM
Default Bleeding Air from my hydraulic steering
At the end of last season my steering was giving me trouble, it was low on fluid. I added fluid but the air was in the system. At speed the boat was all over the place. How do I bleed air from the system. Is it as simple as just working the wheel back and forth or do I have mechanic do it.....
I know, I am a bad boat owner.... : -(
wannabe is offline
Old 06-14-2016 | 11:37 AM
thirdchildhood is offline
Old 06-14-2016 | 11:41 AM
F-2 Speedy's Avatar
take the belt of the ps pump and spin it with a cordless drill while someone is turning the wheel lock to lock, add fluid as needed
F-2 Speedy is offline
Old 06-14-2016 | 11:53 AM
If this works then why not just do it with the engine running? I don't see how this can purge the trapped air.
Old 06-14-2016 | 12:24 PM
F-2 Speedy's Avatar
why run the engine when you don't need to, you can spin it faster with a drill than it will turn at idle...........and yes it works well
Old 06-14-2016 | 01:18 PM
Hmm. Interesting that you can bleed it without loosening any fittings!
Old 06-14-2016 | 01:48 PM
F-2 Speedy's Avatar
any air burps back into the pump reservoir, Brad Smith showed me this years ago, and why would I doubt him ??
Old 06-14-2016 | 01:52 PM
I once had my power stearing fail such that I could spin the steering wheel freely, round and round. I thought there may be air in the line, but to my surprise my hydrolics were pressurized...Never heard of such a thing before, but a few pounds of air and all worked perfect. Any chance you have that going on? or anyone knowing about these things know why the same systems view air in a completely opposite capacity?
scottgjerdingen is offline
Old 06-14-2016 | 02:05 PM
I'm not doubting it. Just wondering why if it's that easy my Zeiger system came with the rather tedious instructions for bleeding!
Old 06-14-2016 | 02:35 PM
jbraun2828's Avatar
I've done it this way and yes it works very well.
jbraun2828 is offline
