Off the shelf Cam- Dyno results >
Old 06-15-2016 | 08:41 PM
Sonic30ss's Avatar
Default Off the shelf Cam- Dyno results
Here are my dyno results from today, Let's have some fun- I'll tell you everything but the cam spec....can you guess?
This build met all my desired results for the 45 Excalibur, looking forward to sea trial.
GM Gen VI Block
4.530b x 4.250s
Callies Crank
Eagle Rod
JE shelf piston
Dart 308 as cast head with high quality valve job
Victor JR
Custom QF 850ish carb
1'' 4 hole
GM roller lifters
XX Hyd Roller Cam
Whistled out to 9:1
[ATTACH=CONFIG]556453[/ATTACH][ATTACH=CONFIG]556455[/ATTACH]
Attached Thumbnails Off the shelf Cam- Dyno results-dynograph.jpg   Off the shelf Cam- Dyno results-dynochart.jpg
Sonic30ss is offline
Old 06-15-2016 | 09:25 PM
Full Force's Avatar
Looks good to me! Man I love my "custom recipe" even more now... Good job!
Full Force is offline
Rookie's Avatar
Close to 741 specs?
Rookie is offline
Old 06-15-2016 | 09:41 PM
close to 731.
mike tkach is offline
Old 06-15-2016 | 10:02 PM
GM Gen VI Block
4.530b x 4.250s
Callies Crank
Eagle Rod
JE shelf piston
Victor JR
1'' 4 hole
GM roller lifters
XX Hyd Roller Cam
Whistled out to 9:1
These are 548s?
Crude Intentions is offline
Old 06-15-2016 | 10:09 PM
When do they go in the boat? Have a 45 also.
Aqua Banshee is offline
Old 06-15-2016 | 10:32 PM
Originally Posted by I.C.U.Lookin
These are 548s?
that is the bore&stroke to make 548.
Old 06-15-2016 | 10:34 PM
ok sonic30ss,spill the beans.
Old 06-15-2016 | 10:40 PM
Originally Posted by Rookie
Close to 741 specs?
Im thinking 741 crane myself. Or close to it.
MILD THUNDER is offline
Old 06-15-2016 | 10:42 PM
Dart 308 irons and shelf cam, with prob quite a bit less lift, spanked you right in the azz
