Off the shelf Cam- Dyno results >
Old 06-16-2016 | 04:23 AM
Sonic30ss's Avatar
Ok- Comp version of 525 efi cam.
Happy motor
https://youtu.be/NNnPRrlXK34
Granted was with dyno headers, but still stout, hopefully reliable power.
No race fuel either Shell 93 out of the pump with 32 degrees timing
Sonic30ss is offline
Old 06-16-2016 | 04:30 AM
Sonic30ss's Avatar
Originally Posted by Aqua Banshee
When do they go in the boat? Have a 45 also.
Shooting for next week, have to hang transom assemblies and finish odds and ends in the bildge this weekend
Old 06-16-2016 | 05:49 AM
So what is the actual Comp Cams part number?
endeavour32 is offline
Old 06-16-2016 | 05:53 AM
Sonic30ss's Avatar
01-446-11 pn
XM289HR-14 Grind #
Old 06-16-2016 | 05:56 AM
SB
Originally Posted by Rookie
Close to 741 specs?
Winner, winner. !!!!!
SB is offline
Old 06-16-2016 | 06:02 AM
Sonic30ss's Avatar
Lol correct!
PS SB thanks for the tip on the sp vs dp debate! No problem building torque in this build ��
Old 06-16-2016 | 06:03 AM
235/243 .610/.627 114 LSA cam.
http://news.compperformance.com/wp-c...I-Camshaft.pdf
Nice combo. Should work well in that big 45 Wellcraft. Excellent torque. Should live a long time , as the lift is reasonable. No .680 lift needed to make the power,and I'm sure the valve spring pressures are reasonable as well.
MILD THUNDER is offline
Old 06-16-2016 | 06:14 AM
SB
Originally Posted by Sonic30ss
Lol correct!
I really feel that subject matter is not a debate. Some things are just what they are.
Are those A/F ratio's from wideband ? Appears so. If they are , looks like one side of carb could stand a little more fuel.
Good luck with the boat - looks like the engine part went well.
SB is offline
Old 06-16-2016 | 06:16 AM
That is a nice flat torque curve.
Wildman_grafix is offline
Old 06-16-2016 | 06:32 AM
Sonic30ss's Avatar
The debate I referred to was in my head, after I looked at the facts, it was over
Yes there are 8 widebands you are looking at cyl 3&4, that run was without air filter, installing it cost 2 hp but also evened out the a/f
