need small block aluminum ported heads .. >
Old 09-27-2002 | 03:53 PM
timucin's Avatar
Default need small block performance (ported) heads ..
will be used in a hot-rod car.Bare is better.dont want to pay for new heads.looking for used...(good-priced)
full port-polish would be perfect!
need help pls
thnx
small block chevy
PS: USED MEANS ,IN PRICE POINT OF VIEW: LOWER THEN NEW PRICE .(AT LEAST WE KNOW THAT WAY IN TURKEY.)
timucin is offline
Old 09-27-2002 | 05:56 PM
rpm
Default small block heads
I have a set of cast dart sportmans that flow enough air to turn 9000. I had them on a 9.5 to 1 383 with 373's and a 4 speed that pulled to the 7600 rev limiter. Complete, fresh and ready to use $2250.00 plus shipping.
920-236-4220
[email protected]
Old 09-27-2002 | 08:55 PM
Vinny P's Avatar
I hate the winter!!
I have a great set of 292 casting # cast iron heads that are ported if interested.
Vinny P is offline
Old 09-27-2002 | 09:45 PM
timucin's Avatar
checkmate: I may be interested but I cannot figure out the heads
can you ps give details
cc?
home made polish or professionally port-polished with flow bench?
flow ?
runner cc?
as I remember:340292.....70's......, angle plug, 64cc
am I right?
thnx
timucin is offline
Old 09-27-2002 | 11:13 PM
Vinny P's Avatar
I hate the winter!!
Yes you are right. But these have been milled down to 62 cc. They have been mildly ported, basically just a debur and clean up the bowl area. I did the port work myself. I never had them flowed so i don't have those numbers. I am also not sure of the runner cc's, but it has to be close to stock being that not alot of material was removed during porting. They have Manley Race Flow stainless valves, bronze guides, teflon seals, they have been cut for 1.450" springs, screw in studs and guide plates. You would need springs to match your application and if you wanted to, a fresh valve job. The valves angles were done recently, but the heads have been run since last done. I can send you pictures if you are interested, just send me your e-mail address..
Vinny P is offline
Old 09-27-2002 | 11:17 PM
timucin's Avatar
yes I am interested .but I need them bare.
cause I need different springs for my cam.
I am in Istanbul -Turkey can you give them to ups?
pls snd me the details including price
here is my e-mail
click to send
thnx
timucin is offline
Old 09-28-2002 | 07:40 AM
Vinny P's Avatar
I hate the winter!!
Timucin:
Pictures and information have been sent to your e-mail address.
Vinny P is offline
Old 09-28-2002 | 10:00 AM
timucin's Avatar
ok thnx I have received.
these are my springs:
99846-16 -Standard diameter H-11 tool steel valve springs for 1.750" assembly height.
your valves are not good for my combination.I only need the castings/bare cylinder heads.
can you pls e-mail me ''cool'' price and we finish this deal soon.
thnx
timucin is offline
Old 09-29-2002 | 11:43 AM
timucin's Avatar
OOPS THERE IS A MISUNDERSTANDING:
THNX
timucin is offline
MidnightRider
08-02-2007 06:35 PM
unbroken
7
11-30-2006 06:04 PM
gripit
9
11-25-2006 06:38 PM
thegreygoose
7
01-03-2005 10:15 AM
glassdave
12
10-19-2004 12:40 AM
