First speed boat.. Formula 271 or Baja outlaw 25 >
Old 06-17-2016 | 09:33 AM
Default First speed boat.. Formula 271 or Baja outlaw 25
So I've decided I want to sell my 21 foot crownline and step up to a speed boat. I really like the 271 and the outlaw 25 (early 2000 models) and I was wondering which one would be the better choice. I mostly ride back in the rivers but make my way out to the Chesapeake bay from time to time. Basically I thought I was set on the outlaw but have read about issues with halls and transom's. What do you guys think about these boats? Also what are key things to look out for on used boats with a 496 ho(wear items ect.)
Rfiresnake is offline
Old 06-17-2016 | 10:32 AM
Formula verses Baja
No brainer FORMULA
Papasmurf is offline
Old 06-17-2016 | 10:35 AM
Dave M's Avatar
Veteran: Navy
Some of the early 496HO's had issues with sensors going bad. I had a 2004 model and it was pretty solid. Those two boats are really around the same size as far as running length. Formula has always been considered high quality. Windshield vs. fairing?
Dave M is offline
Old 06-17-2016 | 10:48 AM
Originally Posted by Papasmurf
Formula verses Baja
No brainer FORMULA
+1
Nuke427 is offline
Old 06-17-2016 | 11:00 AM
mjpcowboy's Avatar
Baja makes a decent boat but Formula is in a different class if you are looking at both.
mjpcowboy is offline
Old 06-17-2016 | 11:18 AM
The 271 is a nice boat and I found one locally. Any idea what are common wear items? The interior is nice, gel coat is glossy and it has around 300 hours on it
Old 06-17-2016 | 11:40 AM
I would also consider a Velocity 280 . Faster then both of the others, deep cockpit, and nice size cabin.
Padraig
Padraig is offline
Old 06-17-2016 | 12:01 PM
Looks wise, I'd choose the OL all day over the Formula, it has the timeless classic offshore look.
Quality wise, I'd probably lean towards the Formula.
Either boat can have rot issues, just spend the $ up front on a survey by a reputable and qualified surveyor. Pay now or pay later...........
TBAG is offline
Old 06-17-2016 | 12:36 PM
onesickpantera's Avatar
I have to agree on the looks. I am not a Baja fan but the 25 is a great looking boat.
onesickpantera is offline
Old 06-17-2016 | 01:12 PM
Definitely get the transom looked at especially if it has thru hull exhaust, and the engine compartment stringers. Two most common areas to go first in wood constructed boats. Dependent on the surveyor, my advice would be get a mechanical guy to check mechanicals, then get a fiberglass guy to come check for soft spots.
Nuke427 is offline
