'96 32' AT- Need Dash/Gauge/Helm pics >
Old 06-21-2016 | 07:12 PM
Default '96 32' AT- Need Dash/Gauge/Helm pics
I'm restoring/repairing this boat and would like to see the original dash layout if anyone has any pics to share. I would prefer to install a new plate (plastic/aluminum/carbon fiber/etc) that would house the gauges, as right now all of the gauges are drilled into the fiberglass.
So if anyone has the correct outside measurement of the plate (or know where I can get one already cut) please send that my way, too.
Thanks in advance.
-Chuck
safeandsound is offline
Old 06-27-2016 | 08:58 PM
I dont have measurments, but I can measure mine if that helps?
Its a '99.
Let me know
TooLateVTEC is offline
Old 06-28-2016 | 12:01 AM
None of the 32's used a plate for gauges. They were all custom cut holes in the dash.
Griff is offline
Old 06-28-2016 | 08:12 PM
I've researched everything and can't find good measurements for a plate- I was hoping someone had already done the hard part......lol. Fountain plates are everywhere, btw!
I think I'll just work with what's there for now- cutting in a Garmin unit and will have to play with the gauge layout.
Thanks for the responses
Old 06-28-2016 | 09:00 PM
Mine has a panel, and the panel even says Active Thunder Boats right on it.
I dont have a straight on pic, but heres what I have right now.
Old 06-29-2016 | 05:57 AM
Cool- so they went to a plate that also incorporated the switch panel. I could really use those specs if you get a chance. Thanks for sharing.
Old 06-29-2016 | 10:22 AM
On my tantrum, I took measurements and made a template for the gauges and GPS. Sent it to Steve at Innotech and he made me overlays in carbon fiber. You should give him a call. He did all the panels for the 32 that Pier 57 did the restoration on.
SHORTFUSE is offline
Old 06-29-2016 | 11:40 AM
Just looked up the Pier57 boat. Impressive. I will check with Steve. thanks for the info.
Old 06-29-2016 | 01:09 PM
My mistake. Never seen a 32 with a factory panel for the gauges.
Griff is offline
Old 06-30-2016 | 06:35 PM
I didn't know they all didn't use them, lol.
OP, if you still want the measurements of mine let me know and I'll try to get them measured tmw evening or something.
