machine marine steering ram disassembly >
Old 06-22-2016 | 07:09 AM
Default machine marine steering ram disassembly
need to reseal machine marine steering rams, anybody know how to get apart without screwing up finish ? thanks Rob
ezstriper is offline
Old 06-22-2016 | 07:11 PM
I've done my stainless Kaama cylinders numerous times. I use leather to cushion the vice and wood and leather to put on tool faces to unscrew the ends. After that, everything else is standard hydraulic cylinder stuff available at any decent hydraulic shop. Reassemble the same way.
CDShack is offline
Old 06-22-2016 | 09:42 PM
Rookie's Avatar
They have a little bit of loctite on them. I needed a little heat to remove the caps without having to clamp them.
http://www.offshoreonly.com/forums/g...der-seals.html
Rookie is offline
