older 2500/3500 4x4 gm Caution.
Old 06-24-2016 | 08:48 PM
Wobble's Avatar
SORE MEMBER
Exclamation older 2500/3500 4x4 gm Caution.
Wife was driving my truck last night and started to back into a driveway, when the left front went through a hole the pitman arm ball joint snapped off. I get all our vehicles checked over once a year at a local front end shop and was about due for this truck.
Four years ago they installed a moog pitman arm due to play in the original gm unit. (He has since stopped installing aftermarket parts unless you bring them to him due to other issues)
After searching I found that moog has a problem with their pitman arms for our applications, so beware[ATTACH=CONFIG]556737[/ATTACH][ATTACH=CONFIG]556738[/ATTACH]
2006 GMC 2500hd crew 4x4 238k miles no lift kit, front keys turned up an inch with shock extension (still nose down)
Attached Thumbnails older 2500/3500 4x4 gm Caution.-part_1.jpg   older 2500/3500 4x4 gm Caution.-part-2.jpg
Wobble is offline
Old 06-29-2016 | 12:30 PM
Grrreat. I just put a Moog on my truck not too long ago. I've always considered them as good as factory, but that is scary.
ChaseO is offline
Old 06-29-2016 | 12:48 PM
Wobble's Avatar
SORE MEMBER
Me too, if you search you will find a lot of broken ones in the dieselplace forum. I went back with GM stock arm
Wobble is offline
