oil thermostat opening temperature is appropriate? >
Old 07-05-2016 | 11:10 AM
Default oil thermostat opening temperature is appropriate?
Ok guys. I have a 468 with a BDS 871. At 3500 rpm cruise my oil temp usually hovers around 140. Needless to say I get a lot of moisture in my oil and it does not burn off at that temp. Trying to remedy this on a budget. I have been researching some oil thermostats. Earls thermostat, mishimoto and another one by improved racing. They are all 160$ and under. The problem I see is that they open up at 180-185 degrees. improved racing has one that opens up at 215. What do you guys think? I thought 180 is too cold and 215 is too warm. What are your guys thoughts? Going this route would be $$$ friendly and easy to install.
Dahlilama is offline
Old 07-05-2016 | 11:22 AM
ROB FREEMAN's Avatar
I think 215 is perfect. As long as you're oil cooler can keep up . And water flow Ect. Keeps the oil around 220 to 230. Some like it lower. But I see no problem in the 220 230 range in the pan. ?
ROB FREEMAN is offline
Old 07-05-2016 | 11:38 AM
Thanks for the reply Rob. I'm assuming the oil cooler can keep up if it can hold it around 140 right now. I wish I could find one that opens at 200. I feel like that's a happy medium. Id really like my oil temps to be between 200 and 215. That's why I have been so hesitant to buy one of these suckers so far
Old 07-05-2016 | 11:44 AM
I think I read on here somewhere that the stock HP500 oil thermostat opens up at 215.
Old 07-05-2016 | 11:46 AM
SB
Never used one, but Mocal says they have a 200*F thermostat. 12AN line sizes
http://www.racerpartswholesale.com/p...il_Thermostats
Edit in: also a 10AN one:
SB is online now
Old 07-05-2016 | 11:58 AM
Thanks SB. anyone have any experience with mocal? I think that may be the one. I need the 10an fittings too! I think I'm ordering it when I get home unless someone says to stay away from it!!! It's only 40-50$ bucks more but it already has the fittings included.
Old 07-05-2016 | 12:09 PM
SB
Haven't used these either, but found this
Mishimoto offers a 165 and a 200*F replacement t-stat for their tstat units for like $13.00
https://www.summitracing.com/search/...nt-Components/
SB is online now
Old 07-05-2016 | 12:17 PM
I saw that you could replace the thermostat on that one but couldn't find the 200 degree thermostat. Now the problem is I have options and I'm very indecisive!!!!
Old 07-05-2016 | 12:20 PM
SB
I can delete one of my posts if you want. LOL.
SB is online now
Old 07-05-2016 | 12:24 PM
HAHAHHAHAH. Too late. I'm already googling the crap out of them!!!! It's just a darn oil thermostat but for some reason it's so hard to decide!!!
