2004 Merc 575 warning siren won't go away >
Old 07-14-2016 | 07:35 PM
Default 2004 Merc 575 warning siren won't go away
It has 76 lbs oil pressure, 110 oil temp and 140 water temp . 30 psi fuel pressure runs great. Just all of a sudden it stays on?? any Ideas
mcprodesign is offline
Old 07-14-2016 | 07:37 PM
all I did is replace fuel lines on the throttle body.. ( on both engines)
Old 07-15-2016 | 08:24 AM
Mine had the same problem, it was a wet oil pressure sensor, a different one than the gauge uses.
JRider is offline
Old 07-15-2016 | 08:39 AM
F-2 Speedy's Avatar
Im assuming their efi ? if so fuel pressure seems low for, should be in the low 40's, are they bravo drives ?? drive reservoir low ? solid tone or interupted
F-2 Speedy is offline
Old 07-15-2016 | 09:18 AM
It sounds like intermittent and solid both cause it changes a little art first. It only comes on after the high idle . It does not come on in the first 10 seconds or so. It will not go away at any rpm. Maybe it is a sensor for low pressure like J rider said? Unhooked the drive reservoir sensor wires and it's half full too.
Old 07-15-2016 | 09:23 AM
what sensors does it have that set that off? I would think oil pressure for sure, water temp for sure . it there more than that to check?
Old 07-15-2016 | 09:25 AM
F-2 Speedy's Avatar
That's a make switch on the drive bottle, when unhooked the circuit is open and will alarm, did you hook the wires together to close the loop
Old 07-15-2016 | 10:46 AM
That's what I thought . Thank you. The guy at the dock was telling me it was the other way
. I will try it
Old 07-15-2016 | 05:41 PM
It is not a high pressure EFI system, that pressure is fine. It has two 90s throttle bodies off dump truck motors...true story.
JRider is offline
Old 07-15-2016 | 05:43 PM
. I will try it
Unplug to bypass alarm
JRider is offline
