WTB SAE3 Adaptors and couplers for SeaTek's
Adapters/housings and couplers. Anyone have a couple of these sitting around? For ZF 301 or ZF 280 or BW 73c's. Or even Twin Disc!
Thanks!
David
Thanks!
David
305 is 216 lbs 301 is 191 lbs so there is very little in it 301c only comes in 1.1-1 if you want overdrive you need to go with the 301 with drop output and custom gears as ZF don't do overdrive in this unit anymore.
Tell you what I do have a twin disc 5075 SC coaxial SAE 3 with overdrive 0.86-1 all you would need to do is find another probably easier than a ZF unit to source.
Is this a second one, or just different angle? Also, do you have couplers? I looked the trains up, it appears it comes in .80 and .92 and greater, maybe they made a .86 at one time.
