What height should K planes be above the running surface. Pro and con for dif heights >
Old 07-20-2016 | 10:41 PM
Default What height should K planes be above the running surface. Pro and con for dif heights
Installing the K plane on Scarab 33 AVS after new transom. They are at the same angle as the hull (angled) What height should K planes be above the running surface?
What are the Pro and con for different heights.
cyrus77 is offline
Old 07-20-2016 | 11:23 PM
Mine are just shy of 1" above the running surface
Griff is offline
Old 07-21-2016 | 05:29 AM
Mine are 3/4
underpsi68 is offline
Old 07-21-2016 | 06:06 AM
Hmm, I thought 1/2" was standard?
JRider is offline
Old 07-21-2016 | 06:25 AM
3/4 min. Mark them out. Double check inside. Make sure nothing is in the way for thru bolting and hose locations. Bottom thickness also has to be watched
class6 is offline
