Repaing  cracked wind screen? >
Old 07-23-2016 | 07:33 PM
26sonic's Avatar
Default Repaing cracked wind screen?
My wind screen on my 02 31 sonic has a piece broken off on the upper corne.r. not sure what material was used to manufacture the wind screen but anyone know what I should use to glue it back?
26sonic is offline
Old 07-23-2016 | 07:41 PM
glassdave's Avatar
Neno the mind boggler
Its probably molded acrylic. I would think if its small ehough just a little crazy clue should do.
08 OPA High Points Champion
glassdave is offline
Old 07-23-2016 | 08:05 PM
26sonic's Avatar
glass dave actuall the piece is like 6 inches long by 3 inches wide, so you think crazy glue would work? any other things to try? i used a clear epoxy and it seemed to work but with this constant heat this weel of 90+ temps it seemed to soften the expoxy and came loose!!!
26sonic is offline
Old 07-24-2016 | 11:03 AM
The glue they use in the construction on acrylic fish tanks will fuse it together. Not sure what it is but its really strong .
buck35 is offline
Old 07-24-2016 | 11:07 AM
26sonic's Avatar
does anyone know what they use for glue on the construction of acrylic fish tanks like buck35 suggested?
26sonic is offline
Old 07-24-2016 | 11:31 AM
Can you buy a new one? If you can I would do it because whenever you try to sell the boat the survey guy will throw that cost into the mix so you might as well enjoy a new one now and get your monies worth out of it. Just my 2 $
Orange quatro is offline
Old 07-24-2016 | 11:43 AM
I googled gluing acrylic and tons of info came up, with instructions on how to do it correctly.
buck35 is offline
Old 07-24-2016 | 02:54 PM
glassdave's Avatar
A buddy of mine used that on his and it worked good. Cant for the life of me I cant remember what it is. Sounds like to big a piece for cryoacrylate (crazy glue)
Old 07-24-2016 | 06:55 PM
Rookie's Avatar
http://www.tapplastics.com/product/r...lic_cement/130
https://www.youtube.com/embed/hT6Ow_cBTps?
Rookie is offline
